Thoughts on this upgrade for a 525 EFI? >
Old 06-29-2015 | 10:16 AM
Default Thoughts on this upgrade for a 525 EFI?
http://www.cpperformance.com/p-26619...y-525-efi.aspx
Who does the programming?
Think it really yields that power?
Pwraddr is offline
Old 06-29-2015 | 10:40 AM
F-2 Speedy's Avatar
Looks like you get a new ecm with the programming done, exchange on the throttle body to, bare heads ? I don't see any valves, springs, retainers in this package. Personally I would put a custom grind cam in them also. The 500 & 525 intake plenums will stop flowing air at around 5500 so it doesn't matter how much CFM the TB flows it wont make any more power, jmo
F-2 Speedy is offline
Old 06-29-2015 | 10:43 AM
Sydwayz's Avatar
Forum Regulator
Keith, shoot a message to REMEDY here on OSO. He's got a great plan that works on the 525s. He's seen nice upgrades on his 33 and a few other boats he's done it too.
Sydwayz is offline
Old 06-29-2015 | 10:47 AM
Is the few mph worth increased drive issues????
Will only a few mph even satify you or leave you wanting more???
You do not need a custom cam grind there are several well known engine builders that offer a "package" similar to what's listed that will work great for you.
offshorexcursion is offline
Old 06-29-2015 | 10:59 AM
I'd spend a little more and add over 250 hp (and lots of broken bravos!) Either way requires 91 octane.. https://whipplesuperchargers.com/ind...&product_id=56
thirdchildhood is offline
Old 06-29-2015 | 04:45 PM
Dave M's Avatar
Veteran: Navy
Am I missing something or do they not quote specific numbers other than "increased"? How much HP does this kit produce?
Dave M is offline
Old 06-30-2015 | 11:10 AM
It says as much as 75-80 hp increase. Now my understanding is that most 525's make 550-560hp.... So is that really 45-55hp increase? Is the HP measured at the prop? Isn't that how merc rates them? 7k for 45-55 hp? How much MPH can one exspect to gain from 55hp per side?
mptrimshop is offline
Old 06-30-2015 | 01:26 PM
...about +2 MPH
BenPerfected is offline
Old 06-30-2015 | 01:40 PM
$7,000 per engine to net 2 mph and the need for 91 octane is nuts! (JMO) One of the best things about the 525 is that it likes cheap 87 octane.
Old 06-30-2015 | 01:49 PM
VoodooRob's Avatar
I have been weighing options and talked to Eddie Young about this kit versus Whipple. The payoff for doing this particular N/A kit, and having to run 91 as 3rd pointed out, just isn't worth it IMO. I have come to the conclusion to swing for the fence (Whipple and run 91) or leave it alone, maintain to the highest standard and enjoy availability of 87.
VoodooRob is offline
