Need a trailer lock boot suggestion >
Old 06-30-2015 | 02:55 PM
Default Need a trailer lock boot suggestion
I have a 7 *16 enclosed utility trailer. My buddy lets me store it behind his shop which borders the Troy, Mich airport but he wants me to put a boot on it. Whats a good one- 14 inch wheels.
Whats a good boot to put on?
Wannabe
wannabe is offline
Old 07-01-2015 | 10:20 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Anything added to the trailer can be removed with enough time and no one disturbing the would-be thief.
-Tongue lock.
-Boots
-Chains
-Locks
For your situation, I would remove something(s) from it the trailer, to make it very unattractive to steal.
Ideally, I'd have some kind of removable tongue and take the tongue with you.
Also, credit member "Wally" with this idea years ago...
Remove your trailer wiring.
He created a pigtail that not only unplugged from the truck, but also unplugged from the trailer and he took it with him.
Thought process: If someone tries to steal the trailer, the last thing they want to be doing is towing without lights.
I'd put that pigtail receptacle hidden up underneath of the front of the trailer; where a thief would have no idea where to go to figure it out.
But one of these:
http://www.championtrailers.com/7-pole-flat-8-ft-whip/
Make it male on the bitter end, and put a female receptacle underneath the front of the trailer. You could locate that receptacle in a lockbox which would make it even more secure.
Sydwayz is offline
Old 07-01-2015 | 11:00 AM
bajaholic's Avatar
Another option to "quickly" disable a trailer from moving is: 1) Take a coated lock cable,(these come in numerous lengths and can be found at Home Depot, etc.) run it through wheel, around the trailer frame and back through the other wheel, then secure cable with a "good Lock". 2) "pull" the emergency stop cable out of its actuator. As soon as they put electric to the trailer, it will LOCK up ALL the brakes.
Like has been said, if they want it bad enough, it will be gone, but at least it will slow them down and hopefully, some one who has not taken the precautions will be the first target.
bajaholic is offline
Old 07-01-2015 | 02:01 PM
I do this, but use a heavy chain - only intention is to slow them down and possibly cause someone else to recognize that somethings not right about the situation and possibly ask them WTF they are doing with bolt cutters near easyrider1340's trailer ! ha!
ALL_IN! is offline
Old 07-01-2015 | 06:56 PM
Its not a matter of protecting your trailer... Its making the thieves looking to the next thing because yours it to much trouble. Security lights work great and cameras (even fake ones). A simple cable and lock, so they can't just grab it and go. Also there are monitors that can be put up around the property.
http://www.homecontrols.com/Seco-Lar...category=77582
kevinb230 is offline
Old 07-02-2015 | 03:16 PM
Yeah I know that if the thieves want it. But it borders an airport and I think thieves want low visibility. Having said that 2 years ago when storing my boat at the exact same location one of my fuel tanks became mysteriously low. One side only. Takes balls and time for someone to siphon 40 gallons of fuel. Or maybe just a couple of 17 year olds and a 24 pack......of bud
So i am looking at the http://immobilize.com/trailer-wheel-boots/
looks pretty good. I want the guys to pull in and basically turnaround.
wannabe is offline
