Imco scx question
Old 07-04-2015 | 04:41 PM
sl
Default Imco scx question
Need some help. Imco scx's - shut one engine down with drive in gear. Couldn't get drive out of gear. When I got back in disconnected outdrive shift cable from shift linkage. I can get neutral and reverse by manually moving cable but no forward. Can't get any cable movement for forward. Any help/suggestions would be greatly appreciated.
sl is offline
Old 07-04-2015 | 10:24 PM
Tinkerer's Avatar
Did you try turning the prop while moving the shift cable? Try turning the prop while you shift it. Unless the drive is damaged it should go into either gear while you turn the prop..
Tinkerer is offline
Old 07-05-2015 | 10:05 AM
sl
Tinkerer I did try to spin it and still can't get forward. Thanks for the feedback!
sl is offline
Old 07-05-2015 | 12:49 PM
Bypass the neutral safety switch and start it in gear and see if you can move it after running.
Griff is offline
Old 07-05-2015 | 06:28 PM
Tinkerer's Avatar
Tell me You didn't force it into neutral when it was stuck - IF you did you may have bent the shifting fork. GOOD LUCK
Steve
Tinkerer is offline
Old 07-08-2015 | 08:43 AM
If you forced it could have damaged the shift linkage or broke a set screw holding the linkage
253 is offline
Old 07-08-2015 | 10:01 AM
sl
Tinkerer, Griff & 253 thanks for your help. Removed drive and it's on it's way back to IMCO. Should know next week what happened.
sl is offline
Old 07-09-2015 | 11:12 PM
Curious what the problem is, please let us know when you get a report from IMCO
253 is offline
Old 05-30-2023 | 11:08 PM
Default Update?
Hey I know this is a super old post but what needed up being the issue? Having the same exact issue
Milam11 is offline
