Off Center
Old 07-06-2015 | 10:56 AM
ROADHOG's Avatar
Default Off Center
On a triple engine outboard V hull, what would be an acceptable off center tolerance?
ROADHOG is offline
Old 07-06-2015 | 08:02 PM
wrinkleface's Avatar
Off center??? Have U had Ur weekly shrink visit lately???????
wrinkleface is offline
Old 07-06-2015 | 09:20 PM
An inch either way should be cake to do, so more than that would bother me.
Cole2534 is offline
Old 07-06-2015 | 10:21 PM
glassdave's Avatar
Neno the mind boggler
zero . . . .
what is off center? are you saying drives are off center?
08 OPA High Points Champion
glassdave is offline
Old 07-06-2015 | 10:49 PM
BUP
Or are you talking about the middle outboard engine spacing mounted in comparison on the transom center line ? Its mounted off center ?
BUP is offline
Old 07-07-2015 | 06:17 AM
ROADHOG's Avatar
Yes, and Yes, Too the best of my measurments the Center engine is off about a 1/2" of transom centerline. The 2 outside motors have equal dimensions off Center motor. They were lined up off Center. One outside motor then is 3/4" further from the outside of stainless transom plate edge.
ROADHOG is offline
Old 07-07-2015 | 06:58 AM
rak rua's Avatar
That's sounds strange.
Anyone else going to put a measure on their outboard rig or is it just me?
RR
rak rua is offline
Old 07-07-2015 | 07:40 AM
I know that as little as 1/4" can cause huge handling problems on a single. A triple, IDK. Are you having problems? If so I think you found the cause.
thirdchildhood is offline
Old 07-07-2015 | 08:59 AM
Did you buy the triple 2.5 cat for sale on craigs?
JRider is offline
Old 07-07-2015 | 09:58 AM
no
