Go Back  Offshoreonly.com > Owners Forum > Nordic
Rage is great on fuel!! >
Old 07-06-2015 | 06:02 PM
Default Rage is great on fuel!!
Spent three days running aroung in my Rage over the 4th and started with full tanks and had just a touch under 3/4 tanks on Monday. Really impressed with the low fuel use!!
zgoo is offline
Old 07-06-2015 | 06:09 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Remember, your fuel tank gauge is NOT linear in it's reading. The bottom of your tanks are V-shaped to some degree, not square.
Once you get down to 1/2 a tank on the indicator, you are probably down around 1/4 of it's total capacity.
Sydwayz is offline
Old 07-06-2015 | 09:44 PM
Good to know, but still I thought I would have burned the tanks dry LOL
zgoo is offline
Old 07-07-2015 | 09:39 PM
Steve Zuckerman's Avatar
These boats are relatively efficient. That and some moderate throttle use will net some good mileage.
If you have saddle tanks like most Nordics, they are rectangular. Sydwayz is correct if you have belly tank, doubtful in a Rage.
Regards,
Steve
Steve Zuckerman is offline
Old 07-08-2015 | 10:36 AM
I have saddle tanks do it should read right. Big motor in a small boat helps. It cruises at 3200 like butter ;-)
zgoo is offline
Old 07-08-2015 | 11:38 AM
Exactly
