Trim tabs >
Trim tabs
Trim tabs
Old 07-09-2015 | 10:23 AM
Default Trim tabs
What kind of trim tabs do you recommend for a 1997 24ft outlaw set with a 502 supercharged engine, that does 80mph.
Jj
conneroutlaw is offline
Old 07-09-2015 | 10:51 AM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
You could probably get away with Bennett (or the like) to save some $$. K-Planes will be more expensive, but are faster and have mechanical indicators. I wouldn't go bigger than 280 on that small of a boat.
Baja_342 is offline
Old 07-09-2015 | 09:21 PM
Thank you for the info. Do they have double hydraulic cylinders attached to them?
Old 07-09-2015 | 11:05 PM
They have just 1 cylinder, but it's a real cylinder, not something made out of plastic with a spring inside for retracting purposes.
They also use a pump similar to the drive trim pump, so they respond quicky
JaayTeee is offline
Old 07-10-2015 | 03:35 AM
Than you for the info., I will have to check them out
Jj
Old 07-15-2015 | 07:15 AM
I had 280s k-planes on both my 24 outlaws.
FBRONCO is offline
Old 07-15-2015 | 08:01 AM
I have a Bennett sport tab (dual piston) setup for sale if you want to go that route.
Crossett is offline
Old 07-15-2015 | 10:30 AM
VoodooRob's Avatar
Definitely go 280s, the Bennett Sport Tabs are mediocre at best, your installing form scratch so do it right the first time. If you find a 380 set-up for sale buy it and trade out the plates + $ for 280s to offset your costs.
VoodooRob is offline
Old 07-15-2015 | 10:54 AM
DiamondPerformance's Avatar
Offshoreonly Advertiser
We sell a lot of the EMI tabs - http://www.diamondperformanceparts.c...cat=263&page=1
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
