XR Lower Gear Set Question?
I have a standard length Imco lower that I purchased used many years ago. It has a 1 1/4 shaft and a blue bearing carrier. I don't believe Imco's came with a blue carrier, so I believe it was rebuilt at some point, and am not sure if any thing else has been changed.
I need to put in a new lower gear set soon, and am not sure what part number I need. I see many different part numbers for a 1.5 ratio,15/19 gear set. How do I know which one I need ?, Should I take it apart first and see what part numbers are on the gears? What differences do I need to know about.
Thanks,
Steve
Thanks,
Steve
Revd Up,
If your lower has the Merc propshaft you will need to use the XR gear set, (43-818928A2).
If it has the Imco propshaft you can use the B1 lower gear set (43-14063A1) or the XR gear set. The difference is the size of the machined hole in the driven gear. Imco sells a spacer that slides on their propshaft to take up the space on the XR driven gear.
Hope that helps.
Dick
Hope that helps.
Dick
