fuel pump oil.  where to add? >
Old 07-10-2015 | 07:35 PM
Default fuel pump oil. where to add?
I took my boat in to get the engine scanned and that all checked out fine but the tech said there was fuel in the pump where there was suppose to be oil. He said to suck it out and add 80w90 to it. I cant find where the fill is for this and was wondering if someone could point me in the right direction?
Z06 FAN is offline
Old 07-11-2015 | 08:33 AM
The side of the raw water pump has 2 flathead screw drain and fill plugs , use green drive lube if u have on hand
airjunky is offline
Old 07-11-2015 | 08:55 AM
Could be one or two plugs depending on the year. Here is a link which others discussed
http://forums.iboats.com/forum/engin...mp-maintenance
AllDodge is offline
Old 07-11-2015 | 11:40 AM
If it only has one fill plug, you should really just dump it out. Trying to suck it out is impossible and you'd be lucky to get half the contaminated lube out.
Griff is offline
