Yearly Alternator Dying >
Old 07-22-2015 | 01:22 PM
Default Yearly Alternator Dying
So -- for the third year in a row, my alternator stopped charging. I'm starting to think this is more than bad luck. It's a minor inconvenience since it is ridiculously easy to change on the boat but I figure there must/may be something else going on. It's ridiculously simple wiring and it all looks like new, any ideas on what to check?
At least two of them were warrantied....
BBCLiberator is offline
Old 07-22-2015 | 01:53 PM
The 1990 Corvettes had a problem with heat and primary
side wiring. The fix was a higher capacity alternator and
bigger primary cable.
myturn is offline
Old 07-22-2015 | 02:03 PM
I have the same flippen issues! It drives me nuts! It's a one wire alt setup.
mj2562@bellsouth.net is offline
Old 07-22-2015 | 03:27 PM
SB
POS Alternator company or Charging more than they should or switching most battery selectors while running.
95% of the time it's a POS alternator.
Oh, and warranty, smoranty. That means, who the f*k cares about warranty if all they do is replace the bad one with another bad one.
SB is offline
Old 07-22-2015 | 03:39 PM
Exactly. Two new batteries and a good Mondo alt this time. I'm tried of messing around.
Old 07-22-2015 | 03:44 PM
35fountain's Avatar
its probably the voltage regulator failure could be bucking each other on a twin engine setup..for start up i put my switches on all or both. after running i put one switch on 1 and the other on 2
35fountain is offline
Old 07-22-2015 | 04:56 PM
Running down a battery (stereo) then using alternator to charge drained battery will overheat and kill it.
MichiMike is offline
Old 07-22-2015 | 05:51 PM
Clean you grounds and make sure theres no paint on any of the mounting surfaces of the alternator. The same thing kills amplifiers too.
kevinb230 is offline
Old 07-22-2015 | 06:51 PM
Since we're here is their any preferred make of batteries? Or is this the same question as what's the best oil for my boat.
Baja Rooster is offline
Old 07-22-2015 | 08:50 PM
Sears Diehard platinum or odyssey group 31 size since you asked.
