Yearly Alternator Dying
I have a dual battery setup on a single engine boat. One starter battery, and one deep cycle. I always start and run on "all" on the battery switch. Once anchored I only run the stereo off the deep cycle. On returning I start and return on "all" for charging. I don't have a killer stereo or anything, and most times I don't even have it on. I'm going to double check the connections, and instead of swapping it out, I'm going to bring it to a shop that rebuilds them so I can at least pinpoint the problem. I'll report back what I find.
BBC Libertator - I'm not sure if I'd connect a deep cycle and a starting battery together. I'd either charge both with an isolator, or better yet, wait till you get back and put a charger on the deep cycle.
Starting and deep cycle batteries are two different animals.
Re-reading your post, you may be better with two starting batteries as a deep cycle is meant to be run down and then recharged.
Connecting two of the same batteries together is only okay if they are in the same exact condition. When batteries are tied together, the weaker is always taking power from the better. Think of two gas tanks with a fuel line connecting each at the bottom. They are always going to be equalized, even if you are drawing/using/filling just one.
Main reason for having two batteries with one engine is to have a back up. If you never use it, that's great...just make sure you charge it here and there.
EDIT -- they just called, the voltage regulator was fried and the switch was cracked (have not seen it yet). $319 late I'm hooked up with some brand new junk. The alternator was repaired and I am now keeping the repaired alternator as a spare as I purchased a new one, and a new switch. I'll also consolidate batteries.
What series alternator? I built a mefi4 efi 1974 Transam, has giant electric fans, fuel pump, engine oil circulating pump, lots of draw. Used a 140 amp powermaster 10SI alternator. It draws around 60-70 amps when everything on vehicles running, have pissed around with 3 replacement alternators as they cook every 20-500 miles, have learned that they can make any alternator put out 140 amps but just like a cheap Lincoln welder they have a VERY short duty cycle and overheat when under a load, especially IF you run battery down. Last one cooked in 20 miles because we ran fans and oil pump with car sitting at chassis dyno so when we started it the alt was under full load, it simply couldn't EVER put out 100+ amps for more than a few minutes without cooking. Went to a 12si, just as bad, went to a modern style one with external AND internal fan, never has a problem since. My boat also has a lot of draw, put a 105 amp Mondo on 13 years ago with internal/external fan and I run battery's down to point boat barely starts and its never cooked, FWIW, Smitty
Shooting it with infrared under full load surface temp was 300+ degrees, there are no windings, stator, diodes, regulators that can take that for long.
I have 3 group 27 marine dual purpose batteries in my boat. Decently large stereo. Used to instantly kill the puny stock Mando alternators. I had a local guy build me a 100a one wire Delco with the marine housing and all new internals for under $100. Did the same for the old man's sea Ray with same issue. Neither one has given me a problem since.
