Water pressure Line question >
Old 07-23-2015 | 09:24 AM
Scarab28's Avatar
Default Water pressure Line question
What are you guys using for the water pressure line from the motor to the gauge. I have a rubber line running to the gauge but it keeps blowing off at 20 lbs pressure. Held on only with a tie wrap.
Scarab28 is offline
Old 07-23-2015 | 11:37 AM
Mine have metal hose clamps. Never have had a line come loose.
Interceptor is offline
Old 07-23-2015 | 12:05 PM
Full Force's Avatar
I use 1/8" line with compression fittings...
Full Force is offline
Old 07-23-2015 | 12:34 PM
Same here. 1/8" plastic/poly tubing.
Griff is offline
Old 07-23-2015 | 12:40 PM
The same, absolutely zero issues.
Ken
minxguy is offline
Old 07-23-2015 | 05:33 PM
X3
Added this setup to mine 2 seasons ago zero problems.
vindicator101 is offline
Old 07-23-2015 | 08:49 PM
Rookie's Avatar
1/8" Nylon tubing with compression fittings.
This is only 6' of tubing, but illustrates what you need.
http://www.jegs.com/i/Bosch-Actron/8...FQ-PaQodiocMkA
Rookie is offline
Old 07-24-2015 | 08:08 AM
T-Mone's Avatar
T-Mone
i use #4 hose w push lock fitings
T-Mone is offline
Old 07-24-2015 | 08:20 AM
I used 1/4" plastic line with compression fittings.. Rust from the block drain kept plugging up the fitting for the 1/8".....
Boatally Insane is offline
Old 07-24-2015 | 09:20 AM
Full Force's Avatar
I took mine off I takes next to stat housing...I have ball valves off water drains for winter draining
