Prop decision >
Prop decision
Prop decision
Old 07-26-2015 | 10:08 AM
Default Prop decision
27 Fountain non step dyno sheet 712hp 692 ft lbs torque. At 5400rpm. I was running a 1.36 bravo 24 pitch labbed bravo prop.
Out drive broke I put a 1.5 drive on it and as you can imagine it will spin it to the moon. I have been looking for a 28 pitch and have found a 31 labbed . I know the 31 was for a specific boat or set up do you think it is to much for my setup.
I spent a bunch on the engine over the winter trying to get by until I can get the 1.36 back
the mayor is offline
Old 07-26-2015 | 10:12 AM
I have a stock 30 inch LH Bravo One for sale. Might be just the ticket.
Padraig
Padraig is offline
Old 07-26-2015 | 10:14 AM
Padraig
Need RH
Old 07-26-2015 | 10:26 AM
OK, thought maybe you were running a lh as I have heard Fountains often like lh props.
Good luck and have fun testing as we are finally getting good weather.
Padraig
Padraig is offline
Old 07-26-2015 | 02:10 PM
Padraig
Same here been 5 weeks since it was in the water. Hopefully it's going to get better
Old 07-26-2015 | 08:19 PM
I would use BBlades test program.
Griff is offline
Old 07-27-2015 | 11:05 AM
Too Stroked's Avatar
Originally Posted by the mayor
Need RH
Every 27' Fountain we ever sold came from the factory with a LH prop.
Too Stroked is offline
Old 07-27-2015 | 11:15 AM
I have a 28 Spinelli that I borrowed to try out on mine but haven't had time yet and I'm getting a 28 Bravo to test soon also. Let me know if you want to try one and we can meet up sometime if the level and debri gets better.
RNGRDVE is offline
Old 07-27-2015 | 02:57 PM
Sounds great let me know when and where
Old 07-28-2015 | 02:08 PM
Not sure when we will be out again but if you are headed down this way before we get out let me know and I can meet you somewhere. I don't get on here too often but Tracey knows how to contact me if you don't already have my #.
RNGRDVE is offline
