Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Would you buy this boat with these cracks? >
Old 07-26-2015 | 02:00 PM
Default Would you buy this boat with these cracks?
This is a 35 fountain that has two areas that are located right at the corner of what Fountain calls the notched hull. The one is directly under the drain plug and the longer chipped/cracked gelcoat is about 4" to the left of the drain plug. As the pictures show the one is about an inch long (the one with the quarter) and the other is just a little smaller in diameter. My concern is over time in the water is water going to creep into the hull and cause structural damage.[ATTACH=CONFIG]543520[/ATTACH][ATTACH=CONFIG]543521[/ATTACH][ATTACH=CONFIG]543522[/ATTACH] I feel comfortable that I can repair the gelcoat.
So my $64,000.00 question is would you buy this boat?
Attached Thumbnails Would you buy this boat with these cracks?-untitled.jpg   Would you buy this boat with these cracks?-untitled1.jpg   Would you buy this boat with these cracks?-untitled2.jpg
fordf350 is offline
Old 07-26-2015 | 02:13 PM
uhhh, yea... youll be fine. take it to a fiberglass shop and $500 later youll never know it was there
315duramax is offline
Old 07-26-2015 | 10:50 PM
Expensive Date's Avatar
No big deal.
Expensive Date is offline
Old 07-26-2015 | 11:00 PM
VoodooRob's Avatar
^^ This
VoodooRob is offline
Old 07-27-2015 | 03:17 AM
What year boat
dennis r is offline
Old 07-27-2015 | 05:39 AM
I would also be concerned about any cracks in that area but if everyone else thinks it's cosmetic then the majority should be right. Get a surveyor to check for rot or wet wood.
thirdchildhood is offline
Old 07-27-2015 | 06:33 AM
Yes get a survey
dennis r is offline
Old 07-27-2015 | 11:12 AM
Too Stroked's Avatar
Neither of those cracks would appear (from your pictures) to be "structural." It looks more like that area bumped into something - fairly common at the transom - and fractured the gelcoat. That said, even a "cosmetic" breach of the gelcoat can lead to water getting into the underlying material and that can be bad. I'd get a surveyor to check the transom with a moisture meter. If it checks out fine, then buy the boat and get the gelcoat repaired immediately.
Too Stroked is offline
Old 07-27-2015 | 11:29 AM
yes spending that much money you should get an outside opinion, but that looks like nothing but a crack in the gelcoat to me
sparky24 is offline
Old 07-28-2015 | 05:56 AM
I would take it to someone that knows boats and have it checked out. Surveyors are probably the least knowledgable people you can find when it comes to boats. Norm @ Bay Performance is pretty good if the boat is local.
Black Baja is offline
