Need Several Big BLock Parts 502 ASAP PLease >
Old 08-07-2015 | 04:06 PM
swan2's Avatar
Cool Need Several Big BLock Parts 502 ASAP PLease
Hi there Guys Im in need of 502 parts
1. Need a good 502 block
2. Need a good 502 crankshaft. would love to have something good to hold up to the Procharger.
3. And also need a new or good used camshaft with lifters.
Any help would be greatly appreciated. Thanks in advance for any and all help and advice.
swan2 is offline
Old 08-07-2015 | 04:28 PM
SB
Gen IV, V, or VI.
Which camshaft ? And if FT or HR.
SB is offline
Old 08-07-2015 | 04:50 PM
swan2's Avatar
The boats is a 1996 model. Carb. engine Donzi has eleletric fuel pump so I dont need the mechanical fuel pump boss on the block. As far as the camshaft something a little over stock but will work with the factory rocker arms and would still be good later down the road for a procharger. If that makes any since at all. Also Im not sure what you mean by FT or HR sorry but please let me know and I will find out. Thank you SB for the help so far. Just to help with you knowing what Im doing the boat came with a 454 which is now trashed. I have a set of Factor 502 heads, Rods, and a set of SRP pistons to use. And wanting to upgrade to a 502, using these parts I already have. Plus the few others thhings im looking for now. Again thanks for the help Sir.
swan2 is offline
Old 08-07-2015 | 05:05 PM
Sick Stinger's Avatar
Brotherhood #1
HP500 cam and lifters help any?
Sick Stinger is offline
Old 08-08-2015 | 12:43 PM
I have a gen 6 Crank, probably needs a polish text me @ 612-701-4440
shaggy 79 is offline
Old 08-10-2015 | 02:45 PM
swan2's Avatar
SB I Sent PM. Gen VI with Hydrolic rollor lifter. As far as the engine goes.
swan2 is offline
Old 12-10-2015 | 09:33 AM
500 hp long blocks?
35fountainrob is offline
Old 12-10-2015 | 03:34 PM
bigboat28's Avatar
I have two gen V cranks. Text me if interestd 740 817 2245
bigboat28 is offline
