454 mag mpi 385 hp Gen V 1992
The engine is a 454 MAG MPI/ FI 385 HP GEN 5 1991 to 1995
I got the casting # 10114182 off of the block today.The engine is a Gen V 1991 to 1995 4 bolt.
I plan on replacing all the lifters with new ones.
I was wondering if you guys could direct me on which lifter / part number to order as well as the intake gaskets kit.
I got a leakdown tester so I'll be checking the system for leakage before I start disassembling the EFI intake.
This is the information that I have found so far:
http://outintheshop.com/faq/casting/castings2.html
Big Block Casting number
CASTING NUMBER # 10114182
YEAR 1991 to 1995
454 4 BOLT GEN 5
YEAR 1991 to 1995
454 4 BOLT GEN 5
Why are you replacing the lifters???
You can use about any brand of flat tappet lifter for a BBC. If you don't break them in right with cam assembly lube, you will most likely wipe out a cam lobe.
