Carrier bearing flange >
Old 08-09-2015 | 08:06 AM
JimV's Avatar
Default Carrier bearing flange
Hey Guy's Im looking for a PTO flange for a stellings stand off box. Merc uses them for triple engine application center motor drive shaft. Anyone know where I can get one? [ATTACH=CONFIG]544006[/ATTACH] Im looking for the center hub
JimV is offline
Old 08-09-2015 | 08:22 AM
Maybe this will help ya Jim. Also, might be worth a post in the wanted section, maybe someone has one laying around
http://www.mercruiserparts.com/Show_...TS+%28BRAVO%29
MILD THUNDER is offline
Old 08-09-2015 | 10:09 AM
JimV's Avatar
Holy crap that's expensive. Thanks
JimV is offline
Old 08-09-2015 | 10:44 AM
I believe i have one . Attaches to about a 5'or6' driveshaft. May need the id measurement of the inner centering flange of the u joint hub from your driveshaft .
airjunky is offline
Old 08-09-2015 | 12:27 PM
I was surfing last night and Shogren has a couple used ones in their parts section.
Griff is offline
Old 08-09-2015 | 03:09 PM
JimV's Avatar
JimV is offline
Old 08-09-2015 | 03:17 PM
mrquad1's Avatar
just a little info the merc carriers use concave washers and the stellings carriers use a flat surface,also you will need the correct shim washers to align for input shaft on gimble shaft from drive
mrquad1 is offline
Old 08-09-2015 | 03:33 PM
JimV's Avatar
PM sent
JimV is offline
Old 08-09-2015 | 03:40 PM
JimV's Avatar
Mine would be the merc carrier then. It has the concave washers I bought the box used with an adjustable jack bolt and the box is slotted. It is a stellings box unless merc got theres from stelling Thanks Jim
JimV is offline
