Panther Prop Selection >
Old 08-09-2015 | 12:09 PM
Default Panther Prop Selection
Any thoughts? 1989 Panther, 461ci with Mega Blowers, Bravo's prop shafts set at 4.5" below bottom, 28" Bravo Ones vs 29" Mirage Plus?
TomR is offline
Old 09-06-2015 | 03:42 PM
I would try the Mirage 25P and then go from there. What is you targeted RPM and est. HP?
BenPerfected is offline
Old 09-06-2015 | 09:13 PM
Rookie's Avatar
My setup is a little different seeing it's a TRS boat. But I have run 3 blade Mirage, 4 blade Braov1's, 4 blade Spinelli's standard and round ear and a slew of other props. The best performing and handling props have been my 25 and 27 Mirages and the coolest looking props were the Spinelli's. lol I would find some 27's or 29's. I swing the 27's with built 454's, some bottom work and no blowers.
Rookie is offline
Old 09-09-2015 | 08:19 AM
hullofjustis's Avatar
Originally Posted by tomr
any thoughts? 1989 panther, 461ci with mega blowers, bravo's prop shafts set at 4.5" below bottom, 28" bravo ones vs 29" mirage plus?
whats the horsepower?
I would try the bravo's but the 3 blades would probably be faster on top end.
hullofjustis is offline
Old 09-29-2015 | 06:36 PM
I'm spinning 28 Bravos 5900@95, so I was thinking 29 Mirage Plus? just curious? I might try the 29s. Didn't know if someone had already made a similar comparison on a similar set up?
TomR is offline
Old 09-29-2015 | 09:07 PM
With your raised x, I wouldn't expect any gains with 3 blades. Handling prob won't be as good as it is now
Unlimited jd is offline
Old 10-03-2015 | 10:23 PM
I'm guessing same! I'm going to have the 28 Bravos tuned this winter.
TomR is offline
