Boating Season might be over...  Prop damage... >
Old 08-10-2015 | 04:57 PM
RollWithIt's Avatar
Default Boating Season might be over... Prop damage...
So, I noticed a slight vibration at slow speeds and low rpms with the starboard motor a couple weeks back. I normally check the leading edge of my props and there are a few minor little nicks so I know that it should be addressed. Got back from the Buffalo Run yesterday and tucked the boat away. Checked on it today and saw two small tears in the trailing edge of my starboard prop.... Not sure if it can be repaired or if I will need a new prop...
Attached Thumbnails Boating Season might be over...  Prop damage...-20150810_165719.jpg   Boating Season might be over...  Prop damage...-20150810_165534.jpg   Boating Season might be over...  Prop damage...-20150810_165519.jpg
RollWithIt is offline
Old 08-10-2015 | 07:51 PM
I would contact BBlades on here or call their shop.
phil_p999 is offline
Old 08-10-2015 | 08:33 PM
call Brett at BBlades they can fix it
innerrage is offline
Old 08-10-2015 | 08:39 PM
RollWithIt's Avatar
I'm gonna give them a call tomorrow. Thanks for the input guys. The consensus in the prop section is that the prop is toast. I'm sure it has all 520 plus hours on it for that motor...
Old 08-10-2015 | 08:44 PM
I've seen props looking far worse than that get repaired and last a lifetime!
Easy repair for the pros IMO.
Kurt Hamilton is offline
Old 08-10-2015 | 09:22 PM
Shogren has some used ones at a good price.
27Fountain is offline
Old 08-10-2015 | 10:13 PM
I would call Murphy's Propeller in Virginia Beach, VA. I have had them blue print numerous props, and their machine shop can fix almost anything, not just hot-rod props, but all props, and they are good at what they do.
http://www.murphyspropellers.com/
Smarty is offline
Old 08-10-2015 | 10:25 PM
That can be fixed! I have had props that look that bad fixed and they are still on my boat! If you have questions feel free to pm me and I will get you the info you need. Rob
catman01 is offline
Old 08-10-2015 | 11:51 PM
Season over for a prop ding? Common now .
ICDEDPPL is offline
Old 08-11-2015 | 01:42 AM
Call Murphy's, if they are not swamped, they will have it done in a day, I have I have driven to VA beach, had them blue print, thin the leading edge, and cup a set of, 27" Mirages for the Magnum , and all of these for the Phantom 30" Bravos, 32" Bravos, and then 34" Bravos, most of the time, they did it in a few hours. Repairing your prop ids what they do, they fix props, they are good at what they do, might as well send both so they can beblue printed, matched, all in the same day, fact not fiction. You might go faster when it is all said and done, get them matched.
Smarty is offline
