One side of crossover hot other cold. No Temp >
Old 08-14-2015 | 08:58 AM
tggrounds's Avatar
Default Crossover problem
[ATTACH=CONFIG]544175[/ATTACH][ATTACH=CONFIG]544174[
Bbc, stainless marine dry, harden marine crossover, thermostat will not open. Will not go over 100 degrees. Crossover is hot on right side and cold on left side. Looks like the water is circulate through the block out one side of crossover then out the bypass to the exhaust? Ran it at 5000 rpm and still no temp.
Attached Thumbnails One side of crossover hot other cold. No Temp-image.jpg   One side of crossover hot other cold. No Temp-image.jpg
tggrounds is offline
Old 08-14-2015 | 08:16 PM
Block of the the bypass with a piece or broom handle. clamp the broom handle inside the the bypass so it wont move then run the engine see what happens. Also take the hose off the side that is hot and connect to your garden hose turn it on and check to see if their is any blockage.
Ken.
blaquebaja is offline
Old 08-15-2015 | 09:09 AM
tggrounds's Avatar
Will try that today.
Thanks Ken!
Old 08-15-2015 | 08:56 PM
Also check to see if your t-stat is stuck open.
Ken
Old 08-23-2015 | 09:16 PM
tggrounds's Avatar
Tried all that and no dice. Cant block off bypass off with t stat in, the water pressure was too high and no cooling for the exhaust. Don't know what to do. Maybe go back to circulation pump.
Thanks Ken.
Todd
Old 08-23-2015 | 11:05 PM
Hi Todd, this has been stuck on my mind since we talked. I have a few ideas if you want to give me a call this week
Unlimited jd is offline
Old 08-24-2015 | 01:30 AM
Where is the seawater pump "in" line feeding the engine at ????? Can't see it in the pics.
Is this the exact kit that you have??? http://www.hardin-marine.com/p-13357...th-bypass.aspx
Is everything installed exactly as shown n the directions??? Tstat maybe upside down???
Griff is online now
Old 08-24-2015 | 05:44 AM
have had to drill 2 small hoes in stat to keep from air locking before on this setup...
ezstriper is offline
Old 08-24-2015 | 10:30 PM
[QUOTE=Griff;4346509]Where is the seawater pump "in" line feeding the engine at ????? Can't see it in the pics.
I don't see it either, mine feeds fresh water at the crossover neck, and I drilled 2 holes in the Tstats. each 1/8 inch, they work great.
253 is offline
