need advice on electric fuel pumps >
Old 08-23-2015 | 06:15 PM
ROB FREEMAN's Avatar
Default need advice on electric fuel pumps
ran the cig couple times now .. it has holley electric pumps ... they run and make noise build pressure then all of a sudden running but no pressure .. its like they loose prime ... both pumps do it frustrating as hell one minute have 7 pds next drop to 0 . any sugestions .. thanks guys
ROB FREEMAN is offline
Old 08-23-2015 | 06:34 PM
From: East Texas Waterfront- running errands if anyone asks
Holley's are sensitive to trash in fuel. Do you have filters between pumps and tanks?
Flightplan is offline
Old 08-23-2015 | 06:35 PM
Are they shutting off while the motors running?
endeavor1 is offline
Old 08-23-2015 | 06:36 PM
Go with Aeromotive A1000s .... Have had great luck with them
Old 08-23-2015 | 06:48 PM
same here,8yrs,,still going
sutphen 30 is offline
Old 08-23-2015 | 06:58 PM
I haven't heard anything great about Holley electric pumps yet for marine use.
Baja Rooster is offline
Old 08-23-2015 | 07:33 PM
BUP
Any water in the fuel ? how hot are your fuel pumps running ? Vapor locking ? Fuel pump cavitation, Too much fuel vacuum (pulling fuel) restricted anti siphon valve ?
BUP is offline
Old 08-23-2015 | 07:56 PM
SB
No electric pumps like to draw fuel....the black/red/blue Holleys are amongst the worst offenders. They need to be mounted real, real low.....and then...they are still not without problems. There are better.....still mount the others as low as you can go.
SB is offline
Old 08-23-2015 | 08:14 PM
Smitty's Avatar
Use anything but Holleys. I run SX pumps. I have injection, so not sure mine could go that low on pressure. But 10 seasons on them, zero issues.
Smitty is offline
Old 08-23-2015 | 09:09 PM
you have to get the right regulator.I modded the efi one w/ a shim plate in betw the 2 halfs and opened the relief hole.also used a bigger ball bearing under the spring.
I knew I was going efi but set my boat up to run on a carb first as I built my whipple motors.
