Play in steering actuator? >
Old 08-16-2015 | 09:01 PM
Default Play in steering actuator?
I recently installed a new style steering actuator and hoses part number 8M0063381 and the tube that the steering came threads onto moves side to side about 1/8"-3/16" can someone please tell me if this is normal or is it wrong can it be tightened?
riverrunner242 is offline
Old 08-17-2015 | 07:35 AM
not sure where you mean where the play is ? there will be some when not running as the P/S system pressure tightens it up
ezstriper is offline
Old 08-17-2015 | 01:36 PM
I have a video of it just not sure how to get it on here so you can see. Do you know how? Thanks
Old 08-17-2015 | 02:35 PM
Put it somewhere else (like youtube) and post the link here.
apollard is offline
Old 08-17-2015 | 09:38 PM
https://youtu.be/GWFDd0fJ2c4
Old 08-18-2015 | 08:19 AM
see valve moving, where is the play ?
Old 08-18-2015 | 11:31 AM
That tube that the cable theads onto and goes through is the valve? The hoses go in right above it.
Old 08-18-2015 | 02:35 PM
I have that same slack in mine. It has external steering and cable from the helm to the actuator with a Brazil valve. I thought it was normal but does create slop at the wheel which I understood could only be fixed with full hydraulic steering. I would love to know if there is a fix as well.
Donzi1979 is offline
Old 08-18-2015 | 06:18 PM
Thanks for the help. Bottom line is hyd assist with fix slop but the play is nothing to worry about?
Old 08-18-2015 | 09:40 PM
I was told only full hydraulic without a cable helm would fix it. Not sure if that is 100% true or not.
