KE / Hardin two stage sea pump
Definitely the seal right behind the bearings was leaking out the weep holes. I plugged the outlet put 10 psi air in the inlet and blew water out the weep holes. Anyone know the numbers of that seal going to try to get one from a bearing supply house.
