How to tell if transmission is going out >
Old 08-21-2015 | 11:36 PM
Registered User
Default How to tell if transmission is going out
I had a oil pressure issue. Fixed pick up. But needless to say was on the water and about half throttle cruising along I hear a big chirp boat dips to left then starts off again. back out of throttles or not chirps then grabs and gets going again
Is this a sign that my tranny is starting to fail. Oil looks good doesn't smell burnt
Sorry it's a 85 Scarab with TRS drives
Steve
sdrockslangers is offline
Old 08-22-2015 | 12:44 AM
What transmission?
picklenjim is offline
Old 08-23-2015 | 03:44 PM
Registered User
Default Transmission
Borg warner transmission. Any ideas on what to check. I have a spare but don't want to pull motor if I don't have to
Steve
Old 08-23-2015 | 04:19 PM
You probably have 72c so check the fluid first.
wannabe is offline
Old 08-23-2015 | 04:52 PM
F-2 Speedy's Avatar
When it does this, I have to pull mine, hope you don't
Attached Thumbnails How to tell if transmission is going out-20150801_143311.jpg
F-2 Speedy is offline
Old 08-23-2015 | 07:37 PM
when they go will start slipping getting on plane...or just cruising along, usually sets off a high trans temp alarm about the same time...not much in those to make noise, auto trans type cluthes...
ezstriper is offline
Old 08-23-2015 | 09:06 PM
Full Force's Avatar
oil pressure in trans? or engine?
do you run pressure gauges? normally once they slip that's it, game over.... very rare they last after that.... sure it's trans bogging it? not ignition or wiring issue??
Full Force is offline
