2002 Fountain Fever 29 >
Old 08-26-2015 | 09:02 AM
Default 2002 Fountain Fever 29
Im looking at buying a 29 Fever, what are the pros and cons?
thanks
bigbird241 is offline
Old 08-26-2015 | 12:00 PM
thanks
Have a 2003 29 525 efi Like the boat very much had it for about six years. The newer hull design I think 2001or 2 is faster than the 27 with the same power. What you want is personal prefrence Twin small blocks a little slower double the maint good safety factor for large open water. The 525 is great all around motor good performance good fuel economy Mi 70s to 80 mph speeds, handles 5- 6 people easily large fuel tank nice cabin and cockpit layout. I would not go less than a 500 or 525 for power 525 is ideal power. Down sides the boat is setup for mid and high speeds high x demition
pt austin pirate is offline
Old 08-26-2015 | 12:12 PM
Default 29 fountain
Sorry for some reason it cut out half my post. Downsides fountain fuel gauges are not accurate(see fountain forum for info) slow to plane high x, they say valve springs should be replace at 250 hrs on 525s (no big deal) cmi headers have issues should be pressure tested (again see forum) And bravo xr drives can have issues I'am sure how you run impacts this same on any boat not just fountain In short had mine 6 years love it looks good rides good excellent performance plan on keeping it . good luck on your purchase P.A. Pirate If I can answer any questions just ask
Old 08-26-2015 | 12:55 PM
In comparison to the 27' Fever...
- cockpit is bigger
- has a cooler
- new models had shorter windshields
- 525 is a great combination in this boat
We had a 27' Fever and were looking to go bigger. My friend (with a 29) suggested that I skip the 29' and go straight to a 35'. We are very happy with the 35'.
ALL_IN! is offline
Old 08-26-2015 | 03:09 PM
The one Im looking at has 500EFI in it. boat has 189 original hours on it. guys says it only runs 68-70 mph. I like the cuddy layout rather than the jump seats, like most other boats.
Old 08-26-2015 | 03:26 PM
Look under the step in between the cockpit area and the cabin, Is it dry and clean?
fordf350 is offline
Old 08-26-2015 | 03:48 PM
29 with 500 efi should run70-75 depending on load en prop. 500 should have e-top headers not the same problem as 525 headers also not sure if valvesprings need change at 250hrs. 500 is a nice solid engine and is a good match for the 29 at 189 hrs you should have a good solid engine for a number of seasons
Old 08-26-2015 | 04:00 PM
From the pics, it looks like a B1 prop. not sure what pitch. I figured it should runs 70's all day long.
Old 08-27-2015 | 08:15 AM
We just bought a 2004 29' with a 496 in it at the beginning of summer. All I can say it that I wish I had done it years ago. Coming from a small Baja the Fountain is light years better. I am happy with the 496, power is adequate but I like the reliability and that I dont have to worry about it at all. We just did a poker run on Vancouver Island BC and we ran the boat 45miles over from Washington, 100 miles for the poker run, and 45 miles back with 6 people and all their gear comfortably and used less then a tank of gas.
monster693 is offline
Old 08-27-2015 | 09:32 AM
A good friend has an 06,, 29 Fever w/ 525 EFI, XR, 1.50 ratio, 26 P. Bravo1 prop,, top speed 76 mph. on gps. w/2 people and 1/2 tank gas.,
253 is offline
