Thanks Tinkerboater..
I cannot thank you enough for the help yesterday in all of the testing. Let me know when you need help and I am there, atleast let me hang around when your building your new secret weapons. Thanks again Dwight
Dwight, did the shortys help your boat any? Faster? Handle better? Worse?? How about some details!!!
TB summed up the testing on the other post. Basically what we found out is that I need MORE POWER. The set up I have now Is as close to ideal for the boat as I can get with the power I have.
I did learn alot about the hull and the lift characteristics of it. My boat has alot of stern lift due to the DDC hull. The best prop rotation on my hull seems to be to spin inboard which, is differint than the AT 37avh likes. That is basically the same hull. Like I said I did learn alot. Dwight
