Opinions on Cam shaft >
Old 09-05-2015 | 08:46 AM
Default Opinions on Cam shaft
I am running this cam in my Procharged 509. Would you consider this an aggressive cam?
duration @ .050 235 243
lobe lift .3590 .3690
lobe separation 114.0
Just to be clear my builder spec,d the cam and I am very happy with it. The reason I ask is just out of curiosity. I appreciate any input.
hadleycat is offline
Old 09-05-2015 | 07:31 PM
no
sutphen 30 is offline
Old 09-05-2015 | 11:38 PM
SFOcean's Avatar
Charter Member #394
Should work with the Procharger pretty well. Not really 'aggressive' but you are most likely not turning past 5k anyhow.
SFOcean is offline
Old 09-06-2015 | 12:24 AM
Real close to the same specs as the merc. 525efi cam. By no means radical but about as "agressive" as can be used with wet exhaust without reversion becoming a serious problem.
dandercam1 is offline
Old 09-06-2015 | 01:01 AM
It looks like a good choice for your combo. Not too aggressive, but plenty of cam to spin 5400 rpms in a 509.
Griff is offline
