HELP with Fragola hose and fittings >
Old 09-07-2015 | 07:02 PM
Tinkerer's Avatar
Default HELP with Fragola hose and fittings
I am doing it as the instructions say. I can't for the life of me get the hose to go on the last 1/4 inch and I have the fitting fixed in a position that gives me great ability to push. what lubricant is the best to use. All I have been able to do is tear up my hands.
Tinkerer is offline
Old 09-07-2015 | 07:53 PM
your turn the hose counter clock wise?I never had a problem w/ those fittings.are you using their hose?
sutphen 30 is offline
Old 09-07-2015 | 09:11 PM
Tinkerer's Avatar
I am using the barbed fittings and there hose. You are supposed to put the end of the hose in boiling water and then oil the inside of the hose and the barbed fitting and just push the hose on. I just can't get the hose to go all of the way up to the plastic stop.
Tinkerer is offline
Old 09-07-2015 | 09:34 PM
You need to grip the hose a few inches back of the fitting.........you know what I mean? If you are gripping it at the end that is going over the barb than the harder you push the harder you are squeezing it shut!
benjen is offline
Old 09-07-2015 | 09:49 PM
SB
Exactly. It works on the same principal as Chinese Fingers. Remember that ? CAn push in, but can't pull out. Harder you pull out, the harder it grips.
SB is offline
Old 09-07-2015 | 10:39 PM
Tinkerer's Avatar
That is what I am doing.
Tinkerer is offline
Old 09-08-2015 | 06:54 AM
I had hell with Aeroquip -8, really difficult.
I clamped a hose fitting in my mill's vise, tightened the hose end to it and had to push like hell. Doing it that way better captures the end and won't let it spin freely so you twist the hose to help it slide on.
Cole2534 is offline
Old 09-08-2015 | 08:28 AM
i put a little engine oil on the fitting,then i heat about 2 inches of the hose with my heat gun.they slide right on and after the hose cools it cannot be pulled apart.
mike tkach is offline
Old 09-08-2015 | 08:37 AM
Absolutely positive the best tool I have bought in a long time . Makes putting together AN fittings a breeze. Worth every cent , I have a ton of an fittings.
http://www.koultools.com/InstructionsAN.html
https://www.youtube.com/watch?v=tTv6d3JfMmY
ICDEDPPL is offline
Old 09-08-2015 | 10:26 AM
That AN installation tool looks like the way to go. Wish I had one of those when I was assembling braided on a daily basis.
sbslinde is offline
