Question re: cockpit covers
I hope this is posted int he right place!
....how tight should they fit? I am having one made by an extremely reputable "boat cover" place and when it was complete, It was so tight to put on, i could barely pull it enough to get the corners latched (cigarette style with the eyes and grommets). It was putting a LOT of stress on the windscreen and I had overall concerns about paint rubbing, and potential cracks to where the windscreen was mounted, the cover shrinking even the slightest would make it unusable.... I mean this thing was extremely tight.... so, they are making a looser fitting one, but my question is, how tight should these things be? if they require a pole anyway so water doesn't sit on it then shouldn't it fit a little looser? Looking for some feedback as to how some of these fit / should fit - a few pics would really be appreciated as well, thanks!
Is it Sunbrella material ? they all stretch a bit over time, mine doesn't have the wind screen and it takes a pretty good pull to get it over the clips, with the pole ring it should fit a bit looser, did you pattern it off the old one, personally I like a tighter fit
Edit: I'd be interested in the other one if they don't have a buyer for it
the new cover is made / being made of Aqualon (sp?) definitely not Sunbrella....
I was told this would actually shrink some over time... but if it did stretch some, that would be better...
no, iot was actually measured and custom made from measurements they came out and took - was just really surprised that they felt it was good for as tight as it was originally though
Couple thoughts:
1) Put some pipe foam over the top of your windscreen before you install any cockpit cover on any boat. This will give the cover some easement when it needs to stretch over the windscreen without directly contacting it.
https://www.google.com/search?q=pipe...FQR0Pgod_3cF8w
(If the kind you buy has adhesive, remove the adhesive before you put it on the boat) Just throw this in a compartment in the cabin when you are out and about. FWIW, I never travel without my cockpit cover. If you break down somewhere and have to leave the boat, it's best covered.)
2) Put the cover on the boat as best as you can and SOAK it with water. This will allow the cover to stretch whatever it may have capability to do so. Then snap the rest of the snaps you could not get. Then let the cover dry naturally, preferably not in the sun (under roof). This will allow the cover to form fit. This may take a couple of sequences of such.
