1999 SONIC 358 Drive Spacer Recomendation
I am going to install drive spacers in my 1999 SONIC 358 twin 550HP/500 HP rebuilt engines with bravo 1 drives and 28 pitch 4 blade bravo props turning inward. I am experiencing prop blowout getting on plane and bow hop once its on plane.
Has anyone installed drive spacers on a 358 to eliminate a similar problem? Should I go with 1", 2" 3" spacers?
Any help is appreciated.
Thanks, Tom
Thanks, Tom
I don't own a Sonic, but have been researching them pretty hard. Seems most folks with the porpoising issue trade up to a 5 blade Hydromotive, same as the Nordic folks. In the Nordic world those things cure damn near every negative effect known to man. You could always try to measure your X-dimension and see if a spacer is truly needed. Not sure what the happy height for a 358 is. Maybe someone will chime in. Good luck either way!
Jay
Jay
Thanks, Tom
Thanks, Tom
The notched transom puts the props in "cleaner" water when running in the rough stuff; which is what allows these heavy boats to carry the nose when needed.
Some folks have gone so far as to fill in the notched transom to run a true squared transom; when they run primarily flat water and have not been able to get the porpoise dialed out.
