WANTED: Mechanical Trim Actuator/s Bravo and Bennett
Looking for mechanical trim actuator for Bravo drive and set for Bennett tabs, cable style. Also will need a 3-4 device Indicator for dash.
Anything available?
Thank you.
Anything available?
Thank you.
The name of the kit is: Actuator kit 846063A1 google for new and used. Working on face plates and indicator parts. i had them at one time.
More info: http://www.marineengine.com/parts/me...alog-00250.htm use the next page and previous page selection to scroll thru the catalog. It gets you some part numbers to google!!
Red short pointer is #849584
Spring for pointer #845014
"socket" for pointer is #845015
Check with any of the guys parting boats all the time for the drive actuator. Not sure whats avail for bennetsm but I went thru the same thing with lencos. Couldnt really find anything. I ended up measuring the ram and found a billet fuel pump mount that fit and mounted the cable to that. to mount the end of the cable I made a bracket mounted to the plate and attacked the cable end to it with a ball swivel.
For indicators I used Trim Sticks heads up setup. way cheaper than others and looks works great.
Ypu just need to measure the cable throw in a 33c , Its been a while but I think it was around 3.5" double check though, then do the math to get your throw right.
