Engine Hoist
I usually end up pulling my engine a couple times a year and it's about that time again. I'm tired of towing the boat to my friends shop to use his forklift, putting the motor in my truck, taking it home, lifting it out with a small hoist to put it on the stand etc. I'd like to build something to use in my driveway. I'm thinking of some A frame contraption like a big swingset that I'd be able to disassemble for storage. It would probably have to be about 10 feet tall. Any of you guys do anything like this?
Jon, Go to your local equipment rental shop and rent a A frame gantry system. Goes together very easily. You will need a horizontal beam of aruond 12 feet long to stratle boat and sit properly on vertical legs. Daily rental rates are around $250/day. A 4" I beam will carry the load of an engine assembly on a center pick. To get engine to clear boat you will need legs to be 10 high. Good luck, Mark
At $250. a day It's cheaper to build your own. If it were your own all would go easy. Rented , you KNOW you'll have problems and need it an extra day or two
Hey Jon , how's the prop or engine coupler ....either bad or did you snag something
.Hey Jon , how's the prop or engine coupler ....either bad or did you snag something
From: Kentucky - where the women are so fast we have to put a governor on 'em!!
I think it was board member JR (Jeff) who posted pictures of one that he made from 4X6 beams, I think. He used a chain hoist to actually move the engine. We used a chain hoist to lift my friend's engine off the mounts for Y-pipe installation. He used a 6x6 beam across several ceiling joists to spread the load. Worked fine.
