epoxy hull?
Old 10-12-2015 | 06:51 PM
Default epoxy hull?
As the title states I just found out my boat is an epoxy boat, what if anything does this mean in terms of care and maintenance, if any? Sorry this is probably a stupid question to most in the industry.
buck35 is offline
Old 10-12-2015 | 08:01 PM
How did you determine this????? I highly doubt a 1995 Fountain is an epoxy boat.
Griff is offline
Old 10-12-2015 | 08:18 PM
Rf 3 posted my pictures on his Facebook page , I asked for any info he said it was epoxy, started life with a Blackhawk drive .
buck35 is offline
Old 10-12-2015 | 08:20 PM
Does it have gel-coat on it ? If it does I highly doubt it is a Epoxy resin layed up boat.
tommymonza is offline
Old 10-12-2015 | 08:22 PM
glassdave's Avatar
Neno the mind boggler
I have to agree with griff, I would be very surprised if it is epoxy. was your boat a custom build for someone?
if it is epoxy, the biggest consideration is if you need to repair anything. It must be done with epoxy only and prep is critical. At that time builders were still experimenting with gel and epoxy so its possible. the super v that Wahoo had was an epoxy boat with gelcoat (that came off in sheets
08 OPA High Points Champion
glassdave is offline
Old 10-12-2015 | 08:25 PM
I have to agree with griff, I would be very surprised if it is epoxy. How did you make this determination?
Boat images were put on Facebook by R3. He said it was an experimental epoxy boat with a blackhawk drive at the start of it's life. Bravo boat now I do believe if I followed the discussion on the image.
Kings11 is offline
Old 10-12-2015 | 08:27 PM
Dave have you ever seen a epoxy hull with gelcoat?
Old 10-12-2015 | 08:28 PM
Correct, you all know as much or more than likely a lot more than me .
buck35 is offline
Old 10-12-2015 | 08:29 PM
glassdave's Avatar
man you guys are fast I edited my first post and hafta do it again lol
Old 10-12-2015 | 08:30 PM
drop the Dial -Up Dave We got this fancy thing called cable internet here in Florida.
