Anybody ever seen or done a Avalanche dually? >
Old 10-26-2015 | 10:48 AM
phughes69's Avatar
Default Anybody ever seen or done a Avalanche dually?
i've always wondered why no one has converted a 2500 Avalanche to a dually. 4 doors, big block short wheel base for easy turning. I remember Chevy made a 4 door short bed dually in 2000 or so that was marketed towards people who pull fifth wheels and campers. I have sen the adapters to convert the 3/4 axles to dually hubs but never seen dually fenders for a Avalanche.
phughes69 is offline
Old 10-26-2015 | 11:50 AM
The Avalanche is on the Suburban Frame, not the pickup. Putting dually fenders on one woud be tough and resale tougher.
Go ahead and give it a shot!!!!
wannabe is offline
Old 10-26-2015 | 12:27 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I owned one, but never considered it. The problem with the Avalanches is their wheel openings are small. That restricts your wheel/tire size choices unless you lift.
Upgrading an Avalanche to a dually is never going to give you the stability you are looking for. I LOVED my Avalanche, but the frame just isn't that of the HD line of trucks. I could see my frame flexing aft of the rear axles when I was towing within factory specs. That's when it was time for me to sell it; and I bought a dually.
Now I have an F350 Superduty & a 2500HD Chevrolet.
My 2003 2500HD Chevrolet long bed/extended cab,
4x4, 4.10 gears, 8.1L gas & Allison 5 speed automatic; pretty much stock on 33" tall tires.
My 2002 2500 Avlanche was:
4x4, 4.10 gears, 8.1L gas & M32 4 speed automatic; lots of bolt-ons including 32" tall/wider tires (see mods below), exhaust, tuner, FIPK, and a few others.
My 2500HD truck tows 12K lbs. MUCH better than my Avalanche EVER did.
I know we can't all afford to have multiple vehicles, but I would suggest dumping your 2500 AV and getting an older HD/Superduty truck for towing only, and picking up a 1500 Avalanche for a daily driver.
Found this pic online, but looks to be a photoshop. To my knowledge, all of the 2500 Avalanches had cladding.
[ATTACH=CONFIG]546982[/ATTACH]
Attached Thumbnails Anybody ever seen or done a Avalanche dually?-b4b9b132d79a11ddcefeaf061632501d%5B1%5D.jpg
Sydwayz is offline
Old 10-26-2015 | 12:35 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
The best bang for your buck to improve towing stability on the 2500 Avalanche (or 2500 Suburban):
2" rear wheel spacers
Ditch the factory 6.5" wide pizza cutter wheels and go to 8" or 9" wide wheels & wider tires.
I was running 17x8 Helo wheels and 265 series E-rated tires on my best setup.
I also had rear airbags on my AV, but in hindsight they may have been actually contributing to my frame sag issue.
Sydwayz is offline
Old 10-26-2015 | 01:40 PM
Arrow craft out of mich would be the place to ck out .
575cat is offline
Old 10-26-2015 | 07:13 PM
phughes69's Avatar
No I don't own one. I have a 1996 C3500 extended cab dually. I was just wondering if anyone had converted one. I remember 20 years ago that the Suburban dually's were a cool conversion and wondered why no one did something similar to the Avalanche or even the newer Suburbans
Old 10-26-2015 | 09:58 PM
Older model Sub but gives the general idea. Like said already the 2500 Av has the cladding which would be problematic. I have actually thought about buying a 2500 Av and swapping out my non clad Av body of my 1500 so I would end up with a 2500 with no cladding.
vindicator101 is offline
