Pulling an engine TRS SETUP >
Old 10-26-2015 | 05:12 PM
Default Pulling an engine TRS SETUP
I am pulling engines from boat and would like to leave transmissions in. Is the easiest way just to unbolt the tranny from the bellhousing?
Simple question, hopefully a simple answer. Thanks.
Mr Maine is offline
Old 10-26-2015 | 05:19 PM
TomFTM's Avatar
U can do it that way , but your gonna have a hell of time putting the motors back in . The easiest and right way would be pulling the drives off and then pulling the motors and trannies together.. If u leave the trannies in they will need to be supported..
TomFTM is offline
Old 10-26-2015 | 05:25 PM
Okay, so pull drives and then unbolt from transom assembly like a bravo (2 big bolts)? Then pull engine/tranny as a unit?
Thanks for the quick response
Mr Maine is offline
Old 10-26-2015 | 05:27 PM
No idea why you'd want to leave the trans in the boat, as Tom said lining it back up will be a major pain. You can leave the drives on and pull it also.
Unlimited jd is offline
Old 10-26-2015 | 05:32 PM
Well that's why I was asking. Initially I thought leaving them in may be easier but that's not the case. Thanks
Mr Maine is offline
Old 10-26-2015 | 06:40 PM
ROB FREEMAN's Avatar
leave the drives on , unbolt the rest if you can move motors forward enough ,, pull the engines and trannies together if you have the room ?
ROB FREEMAN is offline
Old 10-26-2015 | 06:49 PM
Well I'm pulling the drives off anyway, wouldn't the input shafts get in the way if the drives were on?
Mr Maine is offline
Old 10-26-2015 | 07:01 PM
donzi matt's Avatar
You can pull them with the drives on, putting them back in you will want to pull the drives first. I pulled the motors and transmissions together.
donzi matt is offline
Old 10-26-2015 | 07:12 PM
Ok, sounds good. I pulled the exhaust which gives a lot more room. Looks like they will be coming out this weekend.
Mr Maine is offline
Old 10-26-2015 | 07:14 PM
donzi matt's Avatar
I always left the exhaust on and just pulled the risers, but it took some contorting to get the motor mount bolts in. How bad was it getting the exhaust out in the boat?
