Do the headers on 2001 500EFI have ports for oxygen sensors? >
Old 10-29-2015 | 11:46 AM
Default Do the headers on 2001 500EFI have ports for oxygen sensors?
I have the factory CMIs and am building a 540 to replace the 500EFI. I want to reuse the headers and use EFI on the 540 but with out a place for a wideband O2 sensor I will have to rething my plan as a new set of headers will add $5K.
22MTR is offline
Old 10-29-2015 | 12:09 PM
F-2 Speedy's Avatar
you can add the 02 bungs to the headers, there not in them from the factory.........I added them to my CMI sweeper headers for dyno testing
F-2 Speedy is offline
Old 10-29-2015 | 03:10 PM
That is what I was afraid of. To weld in oxygen sensor bungs properly, the headers will need to be normalized/stress relieved and pressure tested after welding. Thinking there will not be any change from $500 for that job.....
Thanks for the info !!!
22MTR is offline
Old 10-29-2015 | 05:01 PM
500? If I could get that much I wouldn't do anything else. Do 2 sets a day before lunch and be enjoying my afternoons more
Unlimited jd is offline
Old 10-29-2015 | 05:56 PM
Ok so what is reasonable to put the bungs in both headers again with pressure test and stress relieving/normalizing ??
22MTR is offline
Old 10-29-2015 | 07:08 PM
About 150 is fair for the hour and a half it would take
Old 10-29-2015 | 07:15 PM
We put the 02 sensors in the tailpipes near the header tailpipe gasket cmi can do it for you ,i think they charge around 150
MDGperformance is offline
Old 10-30-2015 | 02:03 AM
Send them in to CMI. They will purge the header, acid the welds & pressure check them. Taking them to someone who doesn't know what they are doing will cost you a motor.
Bawana is offline
Old 10-30-2015 | 05:46 AM
added 2 at diff locations to my lightnings
ezstriper is offline
Old 10-30-2015 | 08:50 AM
I recently posted a thread with some pics of bungs being welded in a set of tailpipes. I would suggest putting them in the tails instead of the headers. It's much easier to deal with the tails. We put them as close to the flange as possible. Do a search on here and you should be able to find the thread. It was posted a few months ago.
Just for reference, we get $100 per pipe. That's $25 for the bung and plug (SS) and $75 to weld it. We polish the pipe after welding so that it looks the same as it did before we welded on it. Obviously, we pressure test them as well. So, a bung in each pipe on a singe would be $200.
Eddie
Young Performance is offline
