Exhaust steam port side only
I was running the boat on the hose this morning and noticed steam from the port side only. Motor is 700 sci with CMI headers and just over 200 hours on the clock. Boat is mainly a freshwater boat but has been in salt a few times. I always flush and wash after being in the salt. Should I be worried? Should I investigate? If so, do I send the headers out to be pressure tested? Anything else to check?
Thanks for the help.
Mark
Mark
Being on the hose tends to cause this most often.
Next time you drop it in, just check again. There were check valves/balls before the thermostat in my 454 MAG that caused this issue as well. I ended up removing them entirely and no more steam
Check the manifold heat as well to triple check.
