6.2  whipple stage 1 ecm reflash >
Old 11-10-2015 | 04:17 PM
Default 6.2 whipple stage 1 ecm reflash
Was considering a whipple stage 1 ecm update on my 6.2's. Anyone have any real world experience to share? Thank you
twin242ls is offline
Old 11-11-2015 | 06:11 PM
What are you looking to gain? My initial gut response would be...don't do it. 6.2s need a ton more work than a tune to perform better. Trust me. I've done it.
Just tuning assumes the stock tune is super far off optimal and you can get gains from that. I don't believe this to be the case.
Captain YARRR is offline
Old 11-12-2015 | 02:27 PM
ecm flash raises limiter to 5600 from 5200. Gain of 10% power =30+ horse. The goal would be to try and turn a few hundred more rpm, and pick up some top end. So long question short would the flash result in 2-300 more rpm from my existing set up?
Old 11-12-2015 | 03:19 PM
You can raise the rev limiter but it doesn't mean the motor (cam/heads etc) will get there. Are you pinned on the rev limiter now?
Trash is offline
Old 11-13-2015 | 08:10 AM
It likely won't get you there. My 6.2s are 400 hp and I'm not to my limit of 5600 yet.
I have some labbed props that I expect will do it when I get around to putting them on.
So at minimum if you do it, you need labbed props.
