Who makes the best leveling kit for 2001 Chevt 3500 crew cab 4x4? >
Old 11-20-2015 | 03:00 PM
Nykamp's Avatar
Default Who makes the best leveling kit for 2001 Chevt 3500 crew cab 4x4?
My tow truck looks low in the front , anybody raise there's up a few inches?
Nykamp is offline
Old 11-20-2015 | 04:39 PM
offshoredrillin's Avatar
it should be a torsion setup where you can raise it, as long as its not a huge amount. just check the alignment after it.
offshoredrillin is offline
Old 11-20-2015 | 07:26 PM
Nykamp's Avatar
Thank bud, hope all is well!
Nykamp is offline
Old 11-21-2015 | 01:23 PM
UCA systems are the best if just leveling is what you are after. These are very high quality I have one of their lifts: http://www.cognitomotorsports.com/ch...eling-systems/
Diamond Dave is offline
Old 11-21-2015 | 02:18 PM
Nykamp's Avatar
Nykamp is offline
Old 11-23-2015 | 03:09 PM
If you're just looking for an inch or so then turn up your torsion bar pre-load a little. I think mine are about 5 turns in on the adjustment bolts compared to stock. Be warned that this changes your toe a little so it is wise to get an alignment afterwards.
KevD815 is offline
