air fuel mixture
Old 11-20-2015 | 08:01 PM
Default air fuel mixture
what is the best way to tune air fuel mixture other than a dyno the old pull a spark plug or are there any economical testers available?
genob is offline
Old 11-20-2015 | 08:16 PM
Full Force's Avatar
Wideband ....
Full Force is offline
Old 11-20-2015 | 09:41 PM
lots of affordable wideband meters out there today.they really help with the tuneup.
mike tkach is offline
Old 11-21-2015 | 07:49 AM
can only speak for the innovate lm1 and lm2 duel channel,they have severed me well in tuning everything from turbo hondas to twin whipple behemoths.very accurate for a hand held.
hoping some day they'll produce a 4 channel hand held.hate holding everything down in the back seat of a speeding boat.it is fun watching my toughbook start to float.
sutphen 30 is offline
Old 11-21-2015 | 08:57 AM
I agree! Innovate DLG-1 dash mount unit works great for my application. I use the LM-2 for use in the shop
Very happy with their system
abones is offline
Old 11-21-2015 | 12:34 PM
need wideband to do correctly
ezstriper is offline
Old 11-21-2015 | 02:43 PM
thanks for the advise do seems with these you must have a bung for the o2 sensor I have dry pipes have you seen any that can be inserted into the ends of the pipes?
genob is offline
Old 11-22-2015 | 09:05 AM
innovate makes an o2 sensor holder,but I feel you will not get decent readings till your moving alot of exhaust past it.split overlap w/ draw fresh air back in and skew the idle mixture readings.happens alot on the race engines that have the sensor close to the end of the collector pipe/atmosphere.
Old 11-22-2015 | 10:13 AM
Default not sure where your tails end up but ..
Water hits the sensor you can kiss em goodbye.
ICDEDPPL is offline
