Cam choice
Old 11-22-2015 | 11:26 PM
Default Cam choice
Im redoing the pair of ZUL motors in my 39' Dominator - one grenaded and one is just a refresh. They are 557" with Dart heads, JE pistons (custom with a slight dome..compression??), Merlin intakes, big holley dominators and big solid cams. Wont know the exact size until the tear down next week but they wouldn't even clean up/run smooth until 3000rpm. Even with good ignitions, tune, fuel, etc. Their big. Anyhoo, Im wondering what schools of thought people have as to whether I stay with the solids and go the same size or bigger, or run a big hydraulic set up. Their IV blocks, and made either 650 or 750hp from ZUL. I like the idea of NOT having to pull exhausts off to adjust valves, but also don't want to change a winning mix from a builder like that - like proofreading a Keats poem
IMPULSE II is offline
Old 11-22-2015 | 11:58 PM
Would be awesome to dyno the running engine first, then you know what you had and you know what you gained.
Ben at precision power offshore does this all the time and its always surprising what he finds. Some famous engine builders "said" power levels are less, some are more.
offshorexcursion is offline
Old 11-23-2015 | 08:05 AM
there is no doubt that a solid roller cam can make a lot of power but today,s hyd roller cams have come a long way.not knowing how old your current setup is or what the cam spec,s are it,s pretty hard to say what direction you should go.after you get the engine apart let us know what you have and we can go from there.
mike tkach is offline
Old 11-24-2015 | 05:29 PM
These motors are not roller, which would be nice. Im also not in the hunt for horsepower so much as what others have found reliable and still made good power. These motors will make well over 600hp without going crazy and that's good enough for me since I am still stuck with TRS drivelines. My trannies are built heavy but as we know, the drives are shakey when you start throwing big horsepower at them.. didn't know if there was a big preference towards or against solid cams that's all. And I absolutely agree about what it says on the "build sheet" is often times not what comes out the pipes! I will keep it posted when their torn down and get the specs for whats in them. and thanks for the replies
Old 11-24-2015 | 06:07 PM
[ am guessing that it is a fairly old build.nobody uses flat tappet camshaft anymore.
Old 11-25-2015 | 11:17 AM
KAAMA's Avatar
Here's a good suggestion on cam choice.... Bob Madara of Marine Kinetics (585) 654-8583 is an excellent consultant on cam combinations for marine offshore hi-perf engines for any existing heads, cubic inches and application you have/want.
KAAMA is offline
Old 11-25-2015 | 12:00 PM
and just like flat tappet camshafts, no one is using Bob anymore either.
snapmorgan is offline
Old 11-25-2015 | 12:49 PM
F-2 Speedy's Avatar
Impulse, if you decide to hydro roller, I have two sets of almost new Howards roller lifters
http://www.offshoreonly.com/forums/s...2-lifters.html
F-2 Speedy is offline
Old 11-25-2015 | 12:55 PM
Snap that +1
GLENAMY 242SS is offline
Old 11-25-2015 | 08:02 PM
just not true about bob.i don,t mean to start anything but i use him and am very happy with his design work and the prices on the parts.except for a few morell lifter problems everything has been perfect.he immediatly sent me replacement lifters at no cost.who else in the marine industry does that?i,m not going to get in a pizzing match with those who don,t like bob,i am simply stating my experiance with him.
