Pulling a motor from the flange of a 177 wieand >
Old 11-28-2015 | 04:19 PM
Default Pulling a motor from the flange of a 177 wieand
Is the 177 wieand blower carb flange strong enough to pull a dressed big block?
Rockyone is offline
Old 11-28-2015 | 05:39 PM
I would NOT do that.
MILD THUNDER is offline
Old 11-28-2015 | 06:47 PM
Double dog dare ya... Take vid and post here.... Like upon next start up if doesn't rip the blower off the first time.
endeavor1 is offline
Old 11-28-2015 | 06:57 PM
straight answer,NO.
mike tkach is offline
Old 11-28-2015 | 07:22 PM
Thanks guys, I didn't think so
Rockyone is offline
Old 11-28-2015 | 10:15 PM
The tolerances inside the supercharger, are very tight. The last thing you want to do, is distort the aluminum case.
There are lots of other ways to lift an engine out of a boat. My favorite, is either a pit pal sling, or, four 1 inch nylon lifting straps, one at each corner of the heads, if no lifting rings on engine.
Old 11-28-2015 | 11:28 PM
The SC is only torqued down to about 15# and the bolts holding it only go into an aluminum manifold less than an inch.
As was said..........NO
Griff is offline
Old 11-29-2015 | 04:10 AM
SB
x 2.
This is what I'd be also be afraid of.
SB is online now
Old 11-30-2015 | 09:15 AM
bcfountain's Avatar
Registered User
hell no.
bcfountain is offline
