What type EGT probes >
Old 11-29-2015 | 06:57 PM
Default What type EGT probes
I just put new stainless marine exhaust on my 516 BBC and I have a place on each side for 02 and EGT sensors and I was trying to find out which probes to use. I was thinking about getting 02 probes and a monitor to run them for setup in different altitudes and upgrades. any info will help.
Warlock98 is offline
Old 11-29-2015 | 10:02 PM
Default weekend warrior answer
I like this place for EGT gauges
http://thesensorconnection.com/gauge...-kit-gas-race-
What I like about it is you can order extra length wire to extend the probe, mine goes all the way to the dash.
I also have Stainless marine exhaust
Most AFR gauges use Bosh 02`s .
ICDEDPPL is offline
Old 11-29-2015 | 10:08 PM
articfriends's Avatar
DONT use gaffrigs, i had them at one time and they read 300 degrees higher than actual temp, i chased it for a while too wasted alot of time, fwiw, Smitty
articfriends is offline
Old 11-30-2015 | 05:55 AM
run 02's and forget the EGT's my .02
ezstriper is offline
Old 11-30-2015 | 05:29 PM
Thanks guys for the info but I guess what I am asking what type probes for EGT and 02 and is there a management systems or gauges to just read the probes I am 1050 carb do not want it to make adjustments I will be pulling all over. I live in Tn pull to Phoenix 2 times a year. I would like this for tunning.
Thanks AJ
Old 11-30-2015 | 06:00 PM
If I had EGT gauges on the motor that detonated I probably could have caught it in time .
ICDEDPPL is offline
Old 11-30-2015 | 06:23 PM
EGTs drop in temperature when you detonate.
kvogt is offline
Old 11-30-2015 | 06:45 PM
You`re right, it causes overheating but the EGTs go down.
Maybe it wasn`t detonation, I have no broken ring lands
or pitting of the piston crown just scuffed piston skirts.
Side note:
Ryan Retter pointed me towards this .. thought it was interesting since you can find the knock frequency for any particular engine.
http://www.lindseyracing.com/LR/Porsche/KS-4.html
https://www.youtube.com/watch?v=oTYS...ature=youtu.be
https://www.youtube.com/watch?v=vlHrarAbyAs
ICDEDPPL is offline
Old 11-30-2015 | 07:00 PM
dan,post a picture.
mike tkach is offline
Old 11-30-2015 | 07:04 PM
14 apache's Avatar
Side note:
That's a nice piece would pay for itself on one bad load of fuel.
14 apache is offline
