Piston dome cc >
Piston dome cc
Piston dome cc
Old 12-10-2015 | 08:59 PM
Default Piston dome cc
I have dome pistons that are advertised at +13.8cc. I put them in the bore .2 in the hole and cc them, I only get -6cc. Bore notch may take up a cc or 2.
What's up with that? So I take the piston and wrap it tight with masking tape and fill the relief to meet the dome, takes14cc. .095 dome on a 4.29 piston comes out to 22cc or so for a measured net of +7cc. Take away a cc for the bore notch and I'm back to my measure of 6.
I need to set the compression, advertised -13.8 and measured -6. What am I missing?
Fyi, I measure the untouched combustion chamber and it spot on 121 as advertised.
Mr Maine is offline
Old 12-10-2015 | 09:10 PM
SB
Domes are + CC. Dish are - cc.
You'd have to make a mold of the top of the piston and then fill( liquid cc measure) that.
SB is offline
Old 12-10-2015 | 09:18 PM
SB
or put piston to tdc, fill that,
Take that cc and add to your gasket added cc, and then add comb chamber cc , and that will all equal your total combustion area cc.
Compare that to your single cylinder cid and that will equal the compression.
SB is offline
Old 12-10-2015 | 09:22 PM
SB, these are domes and that's what I did.
First I put the piston in the hole .182 with a bit of grease to seal. Took 37cc to fill plexiglass on top. Calculated 43 for a net of +6cc.
Tape around piston, fill with liquid to top of dome I get 7cc. Assume the 1cc difference is the bore notch at top of bore.
Looks like I need to use +6 as measured not +13.8? These are a small .095 dome, no dish here.
Mr Maine is offline
Old 12-10-2015 | 09:28 PM
SB, the dome sits above the deck so I can't use that method.
Mr Maine is offline
