Battery explodes! Why? >
Old 12-12-2015 | 08:08 PM
Default Battery explodes! Why?
Drove over to check boat in storage when I noticed water under boat. To my surprise it was battery acid dripping from drain. It has a factory installed 3 bank pro charger (3-10 amp banks) and one battery had exploded causing one h*** of a mess. Batteries 1 year old (lead), water level OK 6 weeks ago. Any ideas?
bsboss is offline
Old 12-12-2015 | 08:25 PM
Over charged
Black Baja is offline
Old 12-12-2015 | 08:37 PM
Boat is 2012, I would think charger would last longer? And would have fail safe to prevent a overcharge!
bsboss is offline
Old 12-12-2015 | 08:48 PM
This is why I don't leave my charger on over the winter. You just can't trust the monitoring circuits to shut down when fully charged. I manage a large fleet of vehicles, trailers with inverters charges and never leave them on the tenders for fear of either the tenders or batteries causing a fire! I have seen batteries short out and melt down causing extensive heat and acid damage.FWIW
abones is offline
Old 12-13-2015 | 10:07 AM
anything that is electrical is prone to failure imo.espically things produced in china.
mike tkach is offline
Old 12-13-2015 | 11:10 AM
I always thought there would have to be a spark to cause explosion?
bsboss is offline
Old 12-13-2015 | 11:45 AM
A lead acid bat being charged emits hydrogen. If your not well vented the hydrogen can fill the compartment, then even a marine battery charger can have enough spark to cause ignition. This and also a lot of heat from a bad battery can cause a red hot cable issue.
I use AGM's
AllDodge is offline
Old 12-13-2015 | 11:51 AM
I'm not sure of the cause , but I'd be spraying the area down with a baking soda and water mixture to neutralize the acid, then a good freshwater flush afterwards.
Old trick my dad taught me many years ago for cleaning battery cables and terminals.
buck35 is offline
Old 12-13-2015 | 12:02 PM
from what I've seen in the past a battery that becomes low on water level can cause a arc between the lead plates, causing the battery to explode.
Brandonb_05 is offline
Old 12-13-2015 | 01:18 PM
GO4BROKE's Avatar
If it is left on charge all winter, it needs to be a charger that drops to 0 amps. Very few do. Most charge at a low rate all the time.
[img][/img]
GO4BROKE is offline
