Engine graphics / photos
Old 12-19-2015 | 04:07 PM
C_Spray's Avatar
Diamond Member #001
Default Engine graphics / photos
Now that the Batboat's gone, my attention is on the engines in my Formula 382.
At 630 hours, I'm thinking that it's about time for a full overhaul. They run well, but one has started fouling spark plugs every 20 hours or so. I had them out 8 years ago (Geez - has it really been that long???) and painted them two-tone silver with brushed stainless panels on the valve covers. I was pretty happy with the results at the time, but looking at it now, they are a bit bland - just lots of different shades of silver.
Given some of the new powder coat and paint technologies, I'm thinking about using some more dramatic finishes this time, like black chrome on the valve covers, prismatic flakes and so on. I want to keep the heads and blocks silver to help spot leaks, but open for suggestions (and especially photos) of engine graphics from the members. Here are the engines and boat as they are painted now:
Attached Thumbnails Engine graphics / photos-p1010126.jpg   Engine graphics / photos-enginerrear20080226.jpg   Engine graphics / photos-enginesrf20080328b.jpg
Engine graphics / photos-enginesleft20080226-large-.jpg   Engine graphics / photos-done20080510-large-.jpg
C_Spray is offline
Old 12-19-2015 | 04:42 PM
F-2 Speedy's Avatar
Good lookin boat, I've never seen a water pump running off the crank before
F-2 Speedy is offline
Old 12-19-2015 | 06:57 PM
BUP
Nice Innovation marine engines and do you have the DPX Outdrives installed ???
Added info - ^^^^ More marine apps run the waterpump impeller off the crank than not. Merc is the majority who does not run theirs that way nor never did.
Volvo Penta ran everything off the crank starting in 1999 but currently with their LS stuff is running them up higher with a pulley / belt off the front side of the engine - plus they use a big pulley to slow the speed down of the impeller rotation. A lot of testing went into that for Volvo. Also Indmar, PCM, Crusader and Marine Power mostly have used crank mounted pumps forever. Innovation Marine engines in the pics from the OP has used crank mounted pumps for years.
I just talked to the owner of Scat Crankshafts in person about this how bad of a effect does these crank mounted pumps have for the crankshaft and any unbalancing and or negative effects.
BUP is offline
Old 12-19-2015 | 07:10 PM
BUP
Spark plug fouling (fuel side related) could be coolant temp / cold running engine and or coolant temp sensor related or the MAP sensor or fuel injectors or fuel pressure regulator related. Also could be ignition (components) related - weak or faulty. I would look at spark intensity first to see if it spark or fuel related before rebuilding completely. Could also be (oil side related ) worn piston rings / bd ring seal and or worn / scored cylinder(s) or worn valve seals
Leakdown tests and or intake manifold vacuum source testing, Comp tests, scan the engine and fuel pressure tests all would be good test to perform.
SORRY to change up your thread but offering IMO some solid advice as well
BUP is offline
Old 12-20-2015 | 06:16 AM
scarabman's Avatar
Hey Chuck,
Hope all is well. Dont know if you have ever had your injectors out or not, but in relation to what BUP said about fuel delivery issues, I had pulled mine a season or 2 ago due to a miss and plug fouling and found that the injector baskets all had a bunch of aluminum oxide crap plugging them. Talked to Innovation and they told me it was a pretty common problem. They mostly attribut it to dgradation of the evap system and long term recommend running fuel line return back to tank. The evap cannister/housing itself is NLA. Anyway, long story short, baskets cleaned, and good to go, at least for now. Just a thought.
Mark
scarabman is offline
Old 12-20-2015 | 12:19 PM
C_Spray's Avatar
Diamond Member #001
All:
I probably will do a bit of diagnostics before pushing to button on complete rebuilds. It's just a lot of hours, and I'd hate to have something catastrophic happen.
I forgot to add that I scored two of these engine shrouds a few years ago. They are the only set in existence. Maybe I could get a painter to run wild on them...
Also attached is a powder coat that I used on an anchor a few years back.
Attached Thumbnails Engine graphics / photos-p1030612-large-.jpg   Engine graphics / photos-p1010862.jpg
C_Spray is offline
Old 12-20-2015 | 01:05 PM
BUP
Nice ^^^^ always like the Volvo DPX installs. Wish they were still around with Innovation Marine. Anymore pics to post ?
Just adding info. Clogged basket filters in the fuel injectors will NOT cause spark plug fouling. This will cause fuel restrictions / lean conditions. A stuck open fuel injector will cause rich to very rich conditions that can turn into spark plug fouling. Changing the basket filters only in the fuel injector is like doing an an oil filter change but not changing the motor oil from the engine. It is best to have all fuel injectors flow tested and cleaned then new basket filters installed.
I am not trying to sell anything but having your fuel injectors tested and cleaned is part of routine maintenance every so often. Most are saying every 4 to 7 years max or before if you can pin point injector(s) problems whenever. If anyone needs info about it let me know. Just saying
BUP is offline
Old 12-21-2015 | 11:32 AM
Tom A.'s Avatar
Check out some of Ron Potter's pieces.
http://www.potterperformance.com/ENGINE-PHOTOS.html
I love the silver engines with a single candy color and black trim.
Tom A. is offline
Old 12-21-2015 | 01:28 PM
Ryan Beckley's Avatar
Racer
Racer
If we can help, let me know. We do most all of the graphics that you see on Potter's Engines, and then he usually clears over the decals.....
Ryan Beckley is offline
Old 12-21-2015 | 03:54 PM
C_Spray's Avatar
Diamond Member #001
Some nice looking stuff, there, Ryan. Thanks, guys! I'm going to play around with Illustrator a little to see what I come up with.
C_Spray is offline
