Header pipes hit air cleaner???
I ditch the stock exhaust and went to Eddie Marine Thunder headers. But where I need to connect the hose to down to the manifold the air cleaners are in the way. I call Eddie Marine and they were scratching their head they were use to carbureted motors. Would K&N air filters clear? Banging my head...
Does the top lid come off the screen ? If so, maybe cut the screen shorter by a touch ?
Edit in: too bad the stainless riser doesn't have a female fitting on the other side. The manifold usually does.
The lid comes off i could cut it down to get the hose on then go test it out to see if it gets enough air and doesn't affect the performance. Here's two pictures I just took straight on.
How is the overhead clearance? If you have enough hatch clearance you could use a spacer like a Whipple to raise the intake 8-10". See if the wife buys it otherwise cutting down the screen would be best bet.
