How tall is a 28' on a trailer? >
Old 01-16-2016 | 05:29 PM
Default How tall is a 28' on a trailer?
Looking at a 28' maybe. Trying to figure out if itll fit in my shop. I have an 8' by 10' door on the shop and 40' deep. Thanks!
dawes11 is offline
Old 01-16-2016 | 07:33 PM
28' Pantera or Skater yes, 28 Cruiser Not!
class6 is offline
Old 01-16-2016 | 07:44 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
There are dozens of variables; not an exact science.
Tire size
Wheel size
Torsion or leaf suspension
Weld together trailer or bolt together trailer
Steel trailer or aluminum
Lifted truck, tires, wheels
Flat land or hill
Pavement or gravel driveway (you can scoop gravel out of the driveway so the rear truck tires dip low just as the windscreen clears a door).
And different boats sit on different trailers at different angles.
I've seen the exact same exact boat/hull on dozens of trailer, and seen as much as 12" of height difference at highest point.
Sydwayz is offline
Old 01-17-2016 | 06:56 AM
Craney's Avatar
You should be ok with a 8' door height. My 28 is 6'-10" tall sitting on a aluminum double I-beam trailer with 15" wheels. My door 8'x12' and clears it fine.
Craney is offline
Old 01-17-2016 | 01:07 PM
Thanks for the input guys. I realize there can be a lot of variables so no answer will be perfect, I guess I am just looking for a general idea if it will most likely work or hell no not even close. I feel fairly confident the 8' door will work and if not I guess ill just have to make it bigger
dawes11 is offline
Old 01-19-2016 | 09:34 AM
My garage sounds like yours. the compass is a very close to the overhead door seal and actually will touch it with my new 2500HD truck. My older truck was slightly lower and had .5" clearance.
slpcamaross97 is offline
Old 01-19-2016 | 09:35 AM
What one are you looking at?
Old 01-20-2016 | 09:52 AM
Stormrider's Avatar
JC Performance Engines
Mine is currently 6'8", but the tongue is cranked down low.
Stormrider is offline
Old 01-20-2016 | 10:37 AM
28 on a continental trailer with 15 wheels goes under my 7 ft tall door opening. With a couple inches to spare .
paul buckner is offline
Old 01-21-2016 | 04:24 PM
My old 28 easily fit under a 8' tall door............until I put the pole in for the cockpit cover
Griff is offline
