Maybe a Real Octane Booster! >
Old 01-19-2016 | 02:03 PM
Default Maybe a Real Octane Booster!
I have been looking for a real, viable gasoline additive that I can use in my 300SX's to supplement our only 91 octane (R+M/2), non-leaded, non-ethanol gas available in Oklahoma to get to 93 (R+M/2) . I have researched most octane additives currently out there. All, in my opinion fall short. They state they can raise pump gas by "x" points of octane. Note that a point of octane is only 1/10 of an octane rating number in R+M/2 rating. So, 10 "points" only raises our 91 to 92 octane! Don't believe it just read the 'fine print" on the current offerings! Looks like the below link is the real deal! Anybody try this stuff yet?
http://race-gas.com/
Taboma is offline
Old 01-19-2016 | 02:17 PM
F-2 Speedy's Avatar
I didn't read it all, 32oz treats how many gallons
F-2 Speedy is offline
Old 01-19-2016 | 04:19 PM
check out boostane
Drock78 is offline
Old 01-19-2016 | 04:43 PM
Quinlan's Avatar
Splash some 110 it smells So good!
Quinlan is offline
Old 01-19-2016 | 04:48 PM
David
I agree check out Boostane. Also the guys on S&F have been running a product called ACES. I have used it for years with no issues. One ounce treats 6 gallons.
Chris Carson and DBR both 2 stroke engine builders have tested it and said it works. It really does not increase octane but lower the combustion temp.
I can get you the number and you can speak wth him about. I do not remember all the details as it was a long time ago when I spoke to him.
Double Rigged is offline
Old 01-19-2016 | 05:04 PM
From: East Texas Waterfront- running errands if anyone asks
RACE GAS
BLENDING CALCULATOR
2 OUNCES OF RACE GAS
WILL RAISE THE OCTANE OF 1 GALLON OF GASOLINE
4 FULL OCTANE NUMBERS (40 POINTS OF OCTANE).
Use the calculator below to determine the appropriate
amount of Race Gas to add per gallon:
1 - GALLON FUEL
Flightplan is offline
Old 01-19-2016 | 05:29 PM
Originally Posted by Drock78
check out boostane
Some testing that my shed some light on the snake oil. I believe the ACES IV is a good product to enhance the characteristics of gasoline and I do use it.
https://www.youtube.com/watch?v=2jbc...layer_embedded
http://members.rennlist.com/951_race...omparison.html
Taboma is offline
Old 01-19-2016 | 07:46 PM
I thought about doing this but wasn't sure if it would be safe for my 500efi's. I use to run it in my motorcycle. And if it is ok what do u do like one gallon to a tank full.
1989mach1 is offline
Old 01-19-2016 | 08:53 PM
VP C5 booster you get 3.3 double it and you can get to 8.0 But you will need a lot of timing to make it burn. not sure if its worth the retuning
class6 is offline
Old 01-20-2016 | 07:03 AM
CIG3's Avatar
2 ounces per gallon
gets you 4 points.
$29.95 for 32 ounces.
100 gal fill up of 91 would be $89.85 to get to 95 octane
CIG3 is offline
