need help with Sea strainer installation? >
Old 01-25-2016 | 06:42 PM
Default need help with Sea strainer installation?
I have 2002 38 lightning and want to install sea strainers. Can anyone please give me some helpful tips and information to help with starting this process ? I am not sure the proper location and where to start? I have 575 SCI motors side by side.
Stevekonther is offline
Old 01-25-2016 | 09:40 PM
1 MAIDEN AMERICA's Avatar
With my 2002 38 semi-stagger, I put each one directly below the pump, fed by through hull pick ups. It would work fine with side by side. Seal drilled holes and use a nut and bolt, no screws, to mount them to the stringer.
1 MAIDEN AMERICA is offline
Old 01-26-2016 | 03:31 PM
Mount them slightly above water level , that way if you ever have to take off lid to clean out debris while boat is in water , you won't flood the boat .
HALLETT FAN is offline
Old 01-26-2016 | 03:36 PM
Mine are forward of starboard engine down low .
575cat is offline
Old 01-26-2016 | 04:29 PM
Team Archer's Avatar
We mount them back to back on the center stringer and thru bolt them together and if you are going to thru hull water pickups I would install full flow ball valves just inside the water pickups.[ATTACH=CONFIG]550142[/ATTACH]
Team Archer is offline
Old 01-26-2016 | 05:13 PM
^^^^ Thats nice set up archer. I like the single screw top as opposed to nuts or wing nuts
I wish I had added the inline ball valve as I have limped back to the hoist on a few occasions as result of full strainer that I was doubtful to clear while I was still in the water..
cmattj is offline
Old 01-26-2016 | 07:52 PM
I mounted both strainers to my center stringer in my 35' and put ball valves on the sea water inlet, I also had Teague add another inlet to the strainers so I can flush motors off the hose.
[ATTACH=CONFIG]550148[/ATTACH][ATTACH=CONFIG]550149[/ATTACH][ATTACH=CONFIG]550150[/ATTACH]
Attached Thumbnails need help with Sea strainer installation?-10308580_10202481772660372_4727385698284805665_n.jpg   need help with Sea strainer installation?-11074106_10204695296757091_633545592867442649_n.jpg   need help with Sea strainer installation?-10421366_10204695296317080_7278791779274870949_n.jpg
m&rautosales is offline
Old 01-26-2016 | 08:48 PM
Good options posted here... definitely install ball valves on inlet hoses going into strainers
HyFive578 is offline
Old 01-26-2016 | 09:04 PM
Not sure I can add much to what is said but here are mine. Like others I have full flow ball valves on the inlet (that is a must IMO) and a added input for flushing. Through bolted.
DSC_2499 by WIldman Grafix, on Flickr
DSC_2501 by WIldman Grafix, on Flickr
DSC_2506 by WIldman Grafix, on Flickr
Wildman_grafix is offline
Old 01-26-2016 | 09:23 PM
One tip to remember is not to mount them too high above the water line as you may create flow issues at idle or low speed travel , you don't want to fight gravity.
RG.
Rick G is offline
