Knocking and pinging....98 Dodge 360 ci.... >
Old 09-20-2002 | 05:22 PM
Waterfoul's Avatar
Gone Fishin'
Default Knocking and pinging....98 Dodge 360 ci....
I've got the tranny issues worked out (finally!!!) but now under a load (like when towing!!) I get some serious pinging. Engine has 81,700 miles on it, oil changes regularly, etc.... Runs well otherwise but does seem to be down on power a bit.
I recently replaced the downstream (after the converter) O2 sensor (after having the computer scanned due to the check engine light being on at LOTO). Thought this would take care of the issue. It didn't.
I've got about a half tank of regular gas now. When it gets to "fill me or I'm gonna quit" low, I'm gonna throw a halof tank or so of premium and some injector cleaner in it and see what happens.
Any other thoughts? EGR perhaps? There are no other codes showing on the computer scan though.
Also, I'm getting 11 mpg on the highway....3:73 rear end. Seems like I should get a few more mpg than this. Gets 7.5 towing the boat!!!! Sucks!! Litteraly.
Waterfoul is offline
Old 09-20-2002 | 05:28 PM
G-Force's Avatar
Dare I say it? Okay, I will....should have bought a CHEVY!!!
Could still be a bad 02 sensor...replaced mine once and it went bad in 2 days. They installed the next one free of charge. Hope you find out what's wrong....
G-Force is offline
Old 09-20-2002 | 05:31 PM
Waterfoul's Avatar
Gone Fishin'
G.....it continued to ping from the moment I replaced the sensor...right out of the driveway (I replaced it myself.....even YOU could have done it).
Oh, and the cop statements on the noise ticket post from Midnight was way out of line there Fabio. Get a damn hair cut you 8 foot tall punk!!!!!
obnoxus's Avatar
Charter Member #1171
OUCH !!!!!!! Kicking the poor guy when he is down !!!!!!!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 09-20-2002 | 05:34 PM
obnoxus's Avatar
MIke,
Go with the injector cleaner, but skip the premium fuel idea,,, you will mess with the knock sensor, throw the timimng off and create more problems.
obnoxus is offline
Old 09-20-2002 | 05:35 PM
G-Force's Avatar
Well...he's closer to my foot that way and doesn't have as far to fall!
G-Force is offline
Smitty's Avatar
Mike,
Could be a few things. Bad tank of fuel? Possible carbon buildup-I have a friend who sells a chemical to add to gas that really works at removing carbon. It is about 15.00 a can and I have used it and it works. Ford had a problem like this and the chemical helped. Also how old are the spark plugs? Also check your engine timing, maybe something is going on there?
Check this stuff out and post up your findings.
P.S. LOTO pics should be there any day!!!
Dave
Smitty is offline
Old 09-20-2002 | 05:37 PM
G-Force's Avatar
Originally posted by Bigwavz
P.S. LOTO pics should be there any day!!!Dave
Hey...got mine today. Thank you VERY much!! Nice job with the camera...
G-Force is offline
Old 09-20-2002 | 05:38 PM
Waterfoul's Avatar
Gone Fishin'
Bigwavz.....not a bad tank....would have to be about 20 bad tanks. As for the plugs...not sure.....were in the truck when I bought it in May. Planned on changing them also this weekend. As for the timing....not even sure how to check it on this truck.
Old 09-20-2002 | 05:57 PM
Smitty's Avatar
I don't know much about Dodges but I'm sure there is a wire somewhere near the dist that you ground out to put timing into base mode, then set to specs which is probably around 8 degrees BTDC. Try asking the guy down the street which wire it is
(that's if you still speak to him!!) otherwise someone here will chime in soon.
Also get those plugs changed and put in the factory recommended plugs!!!
Smitty is offline
